Are These In Good Condition???
texasz
Say! I just thought of something. You say that this will rev a couple hundred RPMs higher on the highway. I have also read that a lightened or an aluminum flywheel will reduce low end torque and RPMs as well are increase top end speed. If a lightened or an aluminum flywheel is used with a 4.11 wouldn't you net about the same results as a 3.9 while saving a little weight too?
