Posted September 5, 200321 yr comment_48696 Just wondering if there is a reasonable way to hook up nitrous with triple webers and a cannon intake? Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/ Share on other sites More sharing options...
September 5, 200321 yr comment_48710 Reasonable?:cross-eye Nope, none that I can think of... you'd almost have to have a NOS fogger nozzle in each of the intake runners downwind of the carbs. Unless you used an airbox such as TWM has and then you could put the nozzle in the airbox, but then, you might not get even distribution to all the carbs. If you had FI it would be simple.... Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48710 Share on other sites More sharing options...
September 5, 200321 yr Author comment_48713 I guess I could drill and tap a hole in each intake port then. Would that be the only real issue? I heard the fogger type is the way to go anyway... Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48713 Share on other sites More sharing options...
September 5, 200321 yr comment_48716 That would probably be the biggest issue.. of course, then you've got to find a way to mount the throttle trigger switch, and plumb the system.Then there is always the issue of enough fuel, but that all depends on how much NOS you are going to use...And then there could be an issue of jetting of the carbs at WOT with the NOS on.. whether or not you would have the right amount of fuel to mix with the NOS so you don't end up burning a piston........you would probably need quite a bit richer mixture when the NOS is on... and would that affect the carbs mixtures when under normal driving? Or would this system have the nozzle that feeds fuel and NOS at the same time? If so, then you'd have to not only plumb in 6 nozzles for the NOS, but you'd also have to plumb up another fuel system for the nozzles.....Lot's of "ifs".....no real answers from me cuz I don't know that I would want to try to figure it out... especially by the trial and error method.. could get expensive....:cross-eye Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48716 Share on other sites More sharing options...
September 5, 200321 yr Author comment_48722 Sounds tricky. I saw this kit at Jegs: http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3786&prmenbr=361It says it has a system that adds the correct ratio of fuel and N20 I think that is the only way to do it, or otherwise it would mess with normal driving. I don't want to change the jets, just add a separate fuel / nitrous assembly. I have never dealt with this system before but it sounds like it might work. Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48722 Share on other sites More sharing options...
September 5, 200321 yr comment_48727 That looks to be one of the systems that puts fuel and NOS into the nozzle, which would make it a lot simpler. You'd only have to plumb another fuel line to supply the solenoids that control the fuel flow to the nozzle......perhaps you'd have to run a seperate line from the tank..that I don't know... Only thing you have to think about now is the rest of the driveline, can it hold up to an extra 150+HP? And do you have the ignition that can hold up to the demands this system would need? I didn't read all the specs on your car on your site.. but that's something else you'd have to consider as well. Only time I've ever been around nitrous oxide was in the dentist's office.... :cross-eye Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48727 Share on other sites More sharing options...
September 5, 200321 yr Author comment_48730 I am thinking of getting a R4 diff and 5 speed. As for the ignition I have a MSD 6AL, pertronix inside a mallory distributor. I think the MSD system should be fine, i hope. I don't know If I am really going to do the N20, but the thought of it all is very entertaining!thanks for your help Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48730 Share on other sites More sharing options...
September 6, 200321 yr comment_48776 Nitrous Works, Edelbrock, TNT, and a few others offer wet systems, Fuel/NOS, with 50,75,100+ shot kits and nozzles that seem safer. There are other things to help too, like low fuel pressure cutoff switches, detination sensors, exhaust temp. sensors, timing retard switches, progressive switches. . . Get your self some NOS Do & Don't books, call some NOS shops then filter out all the BS and probably get a proven system that has been used by others,and not design one on your own. Your ride looks like you have some nice power under the hood now. Are you wanting to go pick on some V8s or planning to rebuild soon? Lots of people learn how much squeeze their motor can take then they rebuild it again with some nitrous happy parts inside that can survive. Good luck, I too enjoy the thought of my other car, a Formula Firebird, having that little more RWHP! Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48776 Share on other sites More sharing options...
September 6, 200321 yr Author comment_48788 Thanks, this subject really warrants plenty of research. I'll take your suggestion and gets some books. Thanks! Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-48788 Share on other sites More sharing options...
September 13, 200321 yr comment_49603 Hey Jason,J.F.Y.I., I was thumbing thru the MSA mini parts catalog and noticed on the inside cover there are books listed there. One of the books was "Sport Compact Nitrous Injection" $19.95, it may have good insite for the Z since a Z parts house in selling this nitrous book? Oh well, just passing it on to ya, later.Craig Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-49603 Share on other sites More sharing options...
September 17, 200321 yr comment_50067 Quote Originally posted by Chino 240Z Hey Jason,J.F.Y.I., I was thumbing thru the MSA mini parts catalog and noticed on the inside cover there are books listed there. One of the books was "Sport Compact Nitrous Injection" $19.95, it may have good insite for the Z since a Z parts house in selling this nitrous book? Oh well, just passing it on to ya, later.Craig I seen that book the other day (or at least one like it) when I was getting my "Restoring your Z" book. It actually had a lot of info in it and might be well worth it for anyone looking to get nitrous for any application.SuDZ Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-50067 Share on other sites More sharing options...
September 18, 200321 yr comment_50134 Funny thing, yesterday I got a sport compact catalog from Summit Racing and that book was in there for $15.95 so now it's a little cheaper! Link to comment https://www.classiczcars.com/forums/topic/7778-nos-and-triple-webers/#findComment-50134 Share on other sites More sharing options...
