Best sounding 240/280 exhaust
inline6
Must be my turn to have a say.
I have had my exhaust set up on the L24 and L28 engines in my car. They sounded very similar, except the L28 was a bit deeper and idled rather rough (cam).
It was a good volume up to about 3500rpm, not too quiet, not too loud, which is good when you are on the highway for an hour or two. Cruising around gave a good burble and drew good attention, but when the twin SU's were opened, the thing got very loud very quick. Rotary drivers became jealous and everyone used to comment on how good it sounded. Not a bit like those buzzy ricer burner jobs. Pushed 110 - 120dB though.
Luckily the stereo pushed 130dB. It was a very practical system.
Second hand Extractors from the trading post finishing in a 2.5 inch collector. 2.5 inch pipe right through into a 2.5 inch cheapie sports muffler with a 2.5 inch tip.
All fitted up at Sebrings on the Gold Coast. I am very happy with it, it was fairly cheap, and it lets the engine rev.
Scott
  • 1 month later...
well I have the coated 6 into 1 headers, good sized glasspack resonator about a foot after the header, 2 chamber flowmaster and a stainless resonated tip.
The sound at idle: a loping v8 (I always get asked if it is a conversion)
idle to 1999 rpms sounds good like a V8
2000-2450 sounds like you're standing inside a huge drum with a gorilla pounding on it....
everything after the 2450 is like a high whining ferrari.
I will reduce the pipe diameter after the resonator to reduce the resonance
and get another flowmaster 40 series but with the 2.25 inch inlet outlet...
and same tip.
All interesting comments regarding various exhaust setups! When I got my Z it had 2.25" pipe with who knows who's muffler at the rear and it sounded OK but, at that point in time I was a newbie to the Z car scene (1983 time frame). Since then and I mean within the last three years, I've reworked the entire car. Currently I have the Super Turbo setup, 2.5", from MSA and I couldn't be happier with the sound and performance of the system. It is attached to a Jet Hot coated 6-2-1 header from MSA. Here is the interesting thing! I have read a lot of posts about the resonance problem at about 2500 rpm but I have not experienced that problem with my system. Is it possible that the additional layer of insulation I added to the interior has damped out that resonance.....maybe yes? Any comments?
  • 3 months later...
Just ordered the MSA Motorsport 6/1 header coated with the MSA 2.5" aluminized turbo exhaust system for my '78 280Z. It has a leak in the stock manifold and exhaust in pretty bad shape. Can't wait to hear the new pipes! Got the MSA system for $414 including coated header and exhaust shipping included. Hope I made a good choice.
  • 2 months later...
That's the setup I've been looking at. Please take pictures and let me know your impressions once you get it all installed!
I've just about decided to go the custom route myself at the moment.. here is what I'm in the process of designing (all 304 Stainless steel)
9 feet of straight 2.5" 304
2 90" 304 Mandrel bends
14" x 5" x 9" Oval SS Magnaflow Muffler
2.5" SS Oval Cat
Simichome Metal Polish (to polish everything before I take it to an exhaust shop).
I'm still looking around for an exhaust tip that I like, but the total so far is $307.55 for the parts.... I might even be getting too much SS piping, but I'd like to have the exhaust shop make a test pipe if I can...
Anyone have any suggestions or comments? Maybe I should think about throwing a glass pack in there somewhere?
I LOVED the sound of the Magnaflow on my Eagle Talon... very nice grumble and pretty loud...
Oh, and hey Prox.. looks like you're in Colorado too...
I have sitting in my garage the coated MSA 6 into 1 header with the 2.5 in pipe and turbo muffler. just waiting for me to finish the other stuff first. I will get some pictures posted as I get started. I am anxious to hear it run myself :love:
I just finished putting the 6-1 on my race motor with 2.25 all the way back and a 5" Supertrapp with 15 plates. It sounds....um....very interesting. Kinda strange. Actually quieter than my street car. Haven't had it above 4000 yet, so I don't really know how it whines, but can't wait. Probably take the pates out for most tracks. Then it will sound right!
steve
Steve, Someday I'm going to upgrade my exhaust to full SS with Supertrapp muffs.
I don't think you'll want to remove all the discs because the design requires the discs to function. Adding discs increases the area that exhaust needs to exit system, removing discs closes down system.
attached is some FAQ from Supertrapp, last chart shows opening in square inches for number of discs. Your 2 1/4" pipe has 3.97 square inches and based on chart (noting caveat at bottom) I think you would want approximately 18 discs.
I'd call for tech help to tune your particular system.
http://www.supertrapp.com/Automotive/technical%20bulletin%202002-10.pdf
  • Who's Online   2 Members, 0 Anonymous, 747 Guests (See full list)
