Welding Replacement Panels
spindel
I'm about to replace cockers and parts of front and rear fenders. Before I cut out the old metal, I'd appreciate some advice.
1) Should I just cut out the bad sections and attempt to cut the edges of the replacement panels to perfectly match the sut on the car (which seems hard to get right), or,
2) Should I try to clamp the replacement panel to the car and cut through it and the car at the same time. This seems like it would result in a perfect match.
Is there a coimmonly accepted "best"way?
Many thanks!
The absolute best way is to cut the replacement section a little longer than the original, while putting a "kink" along the overlap section. So that when you lay the repair panel under the orig. panel, the two pieces lay flat creating a nice level seam. Stitch weld it then use filler to smooth and you'll have a nice blended repair patch. Eastwood's has a tool for making that "kink", some sort of crimping tool.
My Dad used to use your 2nd method when replacing rear qtr panels on cars. Use the thinnest cutting disc you can find to minimize the gap that is left after the cut. And make sure you do small stitch welds to keep from warping the metal. I would slowly weld the entire cut, then grind down smooth and fill where necessary.
