Posted September 10, 200321 yr comment_49330 hey,its now smoking pretty bad after i addes some mistre oil..in the enging.. i pulled the plugs and there all covered with oil..then theres oil coming out of the exahous.. flange gasket...what show i do? some one said that is lowered the viscasity of the oil now the oil is going through the valve seals...what should ido from here..flush out the oil...then what..will i need a vavle job..?THANKS,steveLong live the Z... Link to comment https://www.classiczcars.com/forums/topic/7849-help-its-smokin/ Share on other sites More sharing options...
September 10, 200321 yr comment_49341 ackI once killed a ford 300, listened to a friend and did the mystery oil thing and ended up with a serious rod knock.get the stuff out! run some 30 weight and run it a little and change the oil again. Link to comment https://www.classiczcars.com/forums/topic/7849-help-its-smokin/#findComment-49341 Share on other sites More sharing options...
September 10, 200321 yr comment_49350 Marvel Mystery Oil is "Top end lubricant" fuel additive, mainly for diesel engines. It's been 25 years since I've read the label but I don't remember anything about putting in your crankcase. Link to comment https://www.classiczcars.com/forums/topic/7849-help-its-smokin/#findComment-49350 Share on other sites More sharing options...
September 10, 200321 yr comment_49367 Originally posted by Victor Laury Marvel Mystery Oil is "Top end lubricant" fuel additive, mainly for diesel engines. It's been 25 years since I've read the label but I don't remember anything about putting in your crankcase. from the siteDescription: ADDED TO GASOLINE:Cleans and lubricates fuel injectors and carburetors Improves gasoline mileage Reduces and prevents varnish and gum build-up Extends spark plug life Safe for catalytic converters and oxygen sensors --------------------------------------------------------------------------------ADDED TO ENGINE OIL: Prevents valve sticking and clatterFortifies properties of engine oil, prevents breakdown caused by extreme temperatures Promotes easier cold weather starts Reduces and prevents acid and sludge formation --------------------------------------------------------------------------------FOR ALL MARINE ENGINES: Inboard and outboard Link to comment https://www.classiczcars.com/forums/topic/7849-help-its-smokin/#findComment-49367 Share on other sites More sharing options...
