I am in the process of building an autocross 73 240z.
Has anyone out there installed the hyperflex bushing kit? Can this installation be done in a garage with normal tools or are special tools required?
Is it even worth upgrading to the hyperflex system or are stock bushings sufficient?
Thanks a million for the feedback people, I really appreciate it!
https://www.classiczcars.com/forums/topic/7895-240z-hyperflex-bushing-set/
That's made by Energy Suspension, right?
If so, its what i put in my 73 a couple years ago. I also did springs & struts at the time- it drives like its on the proverbial rails! My car was at a friends Muffler/Brake shop at the time, so i had him install it all (i think about $300US).
It can be done at home, plenty of us do, providing you have basic tools, space, and ability. I would definately recommend urethane, especially for a track or autoX car.
also, i just got the following price quote on the kit for my 74- told him i would post his info here, so thanks for starting this thread! Here his email:
Kit will included: front & rear control arm bushings, front strut rod
bushings, front & rear bump stops, rack & pinion bushings, differential
carrier mustache bar bushings, steering coupler bushings, front end
links, tie rod end boots, transmission crossmember bushings, rear sway &
end link bushings. Cost $136.00 + $8.00 shipping
Thanks You,
Carlos Don
Bonwitt Enterprises Inc.
14395 Sw 139 CT #109
Miami FL 33186
Ph. 305-251-4594
Ebay id: competitionwarehouseusa
Paypal account: carlos@competitionwarehouseusa.com
I'll be ordering when the snow hits NY-
*this is the exact kit in Victoria British that lists for $219.00!
Hope that helps some of you,
Jeremiah
