Posted September 14, 200321 yr comment_49724 I'm restoring a 1970 Fairlady Z and I need to replace the heater control panel. My "Off" is on the far right and I've not seen one like this."heat vent off""heat room""room def"I also want to change the control mechanism. Is it possible to use one of the more common heater control panels and connect the cables differently so that everything does what its supposed to? Alternatively, is there a source for a direct replacement for my panel? Thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/7904-heater-control-panel-questions/ Share on other sites More sharing options...
