5speed tranny
78 280zcar
You'll need to fabricate a cluch pedal mount, put in a clutch master cylinder and mount, not sure if you'll need a new speedo cable but probably. Might be easier finding a firewall from a wrecked manual body.
There a posts on this site regarding this so do a seach and see.
Good luck
There's no need to "fabricate" a clutch pedal mount. You need to look up in your pedal cluster and see if the bracket has the mount for the clutch pedal. if so, then hit the boneyards and grab the pedal assembly. I can't remember if the auto's were differant, or if the clutch pedal was simply eliminated from the auto pedal cluster.
If they are differant, you need to get the whole pedal cluster from a manual. The whole through the firewall already exists for the clutch master cylindar and such. just knock out the rubber plug.
so, you will need the following.
Manual Trans
flywheel
Clutch master cylindar
clutch slave cylindar
all hoses and lines
clutch kit (throwout bearing, pilot bushing, clutch disc, pressure plate)
Have the flywheel resurfaced if need be
pedal and or pedal cluster
interior shift boot
dust shield from the manual
you may need the center console from a manual also
Case of beer
Extra set of hands
probably a full weekend
you may also need the starter out of the manual as well.
On the '71 240Z that I switched from auto to manual, the pedal brackets were all there; just needed the pedal. The hole in the firewall for the clutch master cylinder was there - with a metal plate bolted over it. Just needed to remove and put in the cylinder. Pretty straight forward on that car.
It looks like all the stuff is there for the pedal mount theres a bar going all the way across, heres some pics so you be the judge, there is a hole for the pedal on the firewall. I dont have to change the differential or the driveline or the tranny controlled vacuum advance(top gear switch)
  • 3 years later...
  • Who's Online   1 Member, 0 Anonymous, 485 Guests (See full list)
