Posted September 16, 200321 yr comment_49926 What are the odds that the door key from my "new" 81 zx parts car would fit the ignition of my 73 240??? Ha it does! I couldn't believe it, they sure looked the same but the 73 key is darn near flat on both sides anymore but I gave it a try, works in the ignition and all the doors and hatch! And this is a good thing because?? I only have one key for the 73 and any copy I've had made from it doesn't work!!! It must have been meant to be that I buy the 81 for a parts car! Even though it's turned into my DD cause I feel bad thinking about tearing up a car that runs so go and looks pretty ok from 20' away.... for a ZX that is... even if it is a lead sled that has a suspension softer than a new loaf of bread BTW, is it possible that this thing (ZX) is really turning 3K at 65 mph in 5th?? what's it got 4.11 gears?? Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/ Share on other sites More sharing options...
September 16, 200321 yr comment_49928 I hate to break it to you but chances are just about any old worn out Datsun key will work. I'm actually kind of surprised that your copy doesn't. Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49928 Share on other sites More sharing options...
September 16, 200321 yr comment_49937 I remember on my first car an '84 Delta my house key would start the thing. It was kind of funny to show people but at the same time gave you an uneasy feeling.SuDZ Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49937 Share on other sites More sharing options...
September 16, 200321 yr Author comment_49941 In another case I would agree with you but in this case I'm the second owner of the 73, I bought it in 79. I've had few passengers in the Z and only a small handful that I can remember that I would have be enough of a gentleman to unlock their door I figure between the passenger door and the rear hatch those locks are about as new as they get, the drivers door and the ignition are probably worn enough that almost anything would work, and the keys I got from the ZX are pretty fresh cut looking. Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49941 Share on other sites More sharing options...
September 16, 200321 yr comment_49957 Yeah, I think I could start my Z with a screwdriver sometimes... I can even pull the key out of the ignition while it is running and it keeps goin. Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49957 Share on other sites More sharing options...
September 16, 200321 yr comment_49959 Same with my '72 240Z. I can pull the key out at any given moment....let alone the fact that I can't even get her to run. Oh sure, she'll start, but the second I go to on, she dies....Rebuild here I come.Brian:cry: Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49959 Share on other sites More sharing options...
September 16, 200321 yr comment_49964 when i was 11 my dad had a morris minor, steak knives worked fairly well :-) Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49964 Share on other sites More sharing options...
September 16, 200321 yr comment_49971 Ha, ha,ha!!! :stupid: :sick: Laughed till my side hurt!! Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49971 Share on other sites More sharing options...
September 17, 200321 yr comment_49991 My friends Dad owned a Nissan pickup. Late 80's model. The key to his truck started both of our z cars right up. Must be a Nissan glitch I guess. Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-49991 Share on other sites More sharing options...
September 17, 200321 yr comment_50024 240z dragon,If it dies when you go from start to on it sounds like a bad ballast resistor.Wire across it for a test.One wire supplies 12v to the coil to start it .On position run thru the resistor,drops the voltage thru a different wire. Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-50024 Share on other sites More sharing options...
September 18, 200321 yr comment_50116 I don't think it was just the Nissan motor company that swapped keys, I think it was fairly common through all japanese cars.We had one key that would start my Dad's Mazda work ute, which was about 5 years old, out Mitsubishi Sigma, and the Suzuki outboard motor on out boat. Made the keyring light though. Other keys wouldn't work though. Strange coincidence maybe. Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-50116 Share on other sites More sharing options...
September 18, 200321 yr comment_50118 I remember my dad said his Morris Minor (or something) key used to open every other Morry aswell........ And mum drove the Alfa Spider to the shops once using the house keys......... Link to comment https://www.classiczcars.com/forums/topic/7936-what-are-the-odds/#findComment-50118 Share on other sites More sharing options...
