Update on the Toyota brake upgrade!
ZmeFly
I have found a new and better source. Anyone that is concidering doing the basic swap for the 70-78 Z with the toyota 4 piston caliper that fits the stock rotors I can now sell them at 125.99 This includes new remaned calipers, new semi-metallic brakes, new pins and rattle clip.
If you are interested in the 4 piston setup using the 300ZX vented rotor, I can sell those at 275.00 for everything but the spacer. I'm still trying to find somone to make these spacers for a good price. If i can the whole set up which would be new remaned calipers (S12W), new semi- metallic brakes, new pins and rattle clip, and new Bendix 300ZX rotors.
If I find a place to make the spacers for the rotors I'll try to sell the whole kit for 325.00 that will include the spacers. I'm hoping with this new shop I'll get lucky.
Let me know what you guys think
toyota remaned, not new, the brake pads are bendix semi-metalics, as is the rotors if you buy the vented rotor set up.
On another note, I should be coming into some Nissan 3.70 LSD's very shortly. If your interested let me know, Im needing some extra cash to fund my need for speed :devious:
Originally posted by mperdue
I wonder why he says it's for vented rotors.
To make it clear as he possible can to sell it quick??
As you see, he mentioned “all models W from wide, casting S12”
These are the ones you are looking for believe me
1 NEW PAIR FRONT DISC BRAKE CALIPERS FITS TOYOTA: 1985-87 4 RUNNER...ALL MODELS; 1975-89 LANDCRUISER...ALL MODELS; 1986-87 PICKUP...ALL MODELS W/ VENTED FRONT ROTORS // CASTING# S12-8 // LIST PRICE = $195 EACH! // REPLACE YOUR RUSTED OR FROZEN CALIPERS // NO RESERVE
i do know that with the stock rotor set up that it will fit with the 14 inch wheel.
some people have said that they have had the vented rotor set up on 14's but then had to shave a small portion of the caliper to make it work.
i dont have any proof or knowledge that it does work, maybe someone else can enlighten.
