original jute material
kats
I've seen a few of the AAMCO mats on auction at eBay over the years, and I do not know if they put their name on the matts, but the ones that I saw looked much different than the ones Mark photographed. The ones I saw had a big "Z" for a logo instead of the "DATSUN" shown on Marks mats. They also were covered with many deep grooves to hold water. I do not know if they made other models of mats for the Z's that were different.
26th-Z,
Thank you for your great photo.I see your rear deck does not have insulator,I mean I see 12 holes on the deck.
My understanding,this is a typical 1969(or Jan 1970) 240Z's featuring.My march 1970 240Z have insulator for the rear deck so holes are covered,just dents like a bowl there.
I will post my rear deck's photo.
Kats
I look forward to seeing the rear deck on yours. As far as I can tell my April 1970 has the same deck as 26th-z's.
I'll post a picture (if I can get my digi camera to work!!!)
regards
Andrew
Interesting. That's just what the mats in my new 280Z look like. Deep grooves and a big "Z" on them. Have to pull one out and look at it closer. Unfortunately, tonight is "fix the new car" night, since I blew the clutch slave cylinder last night on the way to a local watering hole, and have to replace it now. Actually found a local parts store that had it in stock! But that's another subject...
Hello,
Thank you very much,26th-Z.I was surprised that 1969 240Z has
tar mat insulator.
mdbrandy,yes this is typical 1969 240Z and japanese fairlady-Z.
abas,your 240Z is april 1970 but yours does not have insulator,this is very interesting and I have to revise my understanding.
I show my march 1970 240Z's rear deck compartment.
There is a insulator covering the floor panel.Closely look at around spair tyre bin,you can see the insulator on the floor too.
http://www.geocities.jp/datsunz903/deckcomp.html
  • 5 months later...
Having just got the remaining jute material from my 1970 car out of storage after 10 years, I thought it might be helpful to post some pictures of what is left as a comparison to the patterns that Kats posted previously, which I think were from a Japanese market car?
hope this is of help to someone.
Andrew
Remaining jute in approximate position when in the car
Thanks Andrew. I made tracings of my old jute for patterns. I have the tunnel jute pattern as well. Your photos will be valuable to me as I compare what I was able to salvage to your "pristine" examples. Has anyone found a proper replacement material? I received a sample from LeBaron Bonney and it is not the same material.
No problem 26thz, let me know if you need any better pictures. I have the rear deck jute too but I think Kats pictures are the same as mine.
Most of the new jute I have looked at over here is also not quite the same, but I keep on looking.:classic:
Hope the z convention goes well.
regards
Andrew
