Posted September 20, 200321 yr comment_50390 hey guys got a 79 280zx i just put on a new (reman) clutch master cyl. and slave cyl. and the thing wont bleed out... im getting air back and forth at the slave cyl. but still no fluid coming through:angry: i have it on car ramps right now so im going to try again see what's what any tricks i'm missing..? thanks chris Link to comment https://www.classiczcars.com/forums/topic/8009-qwick-help-please-i-wanna-drive-tonight/ Share on other sites More sharing options...
September 20, 200321 yr comment_50413 There is probably air trapped in the master cylinder. Try opening the bleeder on the slave cylinder just a very little bit, and pump the clutch pedal a couple times. Opening the bleeder slightly will give a little backpressure on the master and hopefully that will get the trapped air out. Most times, after the air is bled out of the master cylinder, you can open the bleeder on the slave and the fluid will feed through with just gravity.Just be sure to keep the master cylinder full while you are bleeding the slave cylinder or you'll end up starting all over. Link to comment https://www.classiczcars.com/forums/topic/8009-qwick-help-please-i-wanna-drive-tonight/#findComment-50413 Share on other sites More sharing options...
September 20, 200321 yr Author comment_50416 backpressure huh ... i'll try that thanks chris Link to comment https://www.classiczcars.com/forums/topic/8009-qwick-help-please-i-wanna-drive-tonight/#findComment-50416 Share on other sites More sharing options...
September 20, 200321 yr Author comment_50420 2 many..... you the man.... worked like a charm, thanks again partner:classic: on the road again chris Link to comment https://www.classiczcars.com/forums/topic/8009-qwick-help-please-i-wanna-drive-tonight/#findComment-50420 Share on other sites More sharing options...
