Posted September 21, 200321 yr comment_50427 I developed a crack in one of my wheel center caps a couple of years ago and it needs refinishing again. Any suggestions on how to refinish the plastic face? Link to comment https://www.classiczcars.com/forums/topic/8013-plastic-wheel-center-cap/ Share on other sites More sharing options...
September 21, 200321 yr comment_50428 Hmmm...it looks like this would be its second repair.What kind of wheel is it from? You might be able to trackdown a replacement.If you can't find a replacement, I would clean out what's in there now and apply some good epoxy putty, sand and repaint it.-OR-If you're good with sheetmetal, cut a rould piece out that would fit the inner diameter on the silver circle. Then, bond it to the plastic cap with some JB Weld, and paint. Link to comment https://www.classiczcars.com/forums/topic/8013-plastic-wheel-center-cap/#findComment-50428 Share on other sites More sharing options...
September 21, 200321 yr Author comment_50475 Thanks for the suggestion- I'll try that. Here is a photo of the wheel - It's a 15x7 Keystone Dyna Lite in a 3 piece design. Can't find them anywhere much less the centre cap! Link to comment https://www.classiczcars.com/forums/topic/8013-plastic-wheel-center-cap/#findComment-50475 Share on other sites More sharing options...
