Posted September 22, 200321 yr comment_50576 Thanks for the replies on my towing questions about the 1972 240-Z. I'm gonna tow it from Manassas, VA to Charlotte, NC this weekend. I figure there's a flange on the drive-shaft at the rear end. What's up front at the trans.? Slip yoke, u-joint or what? I just want to pack the right tools and not the whole shop when I go to pick this car up. Weeeeee!!!!!!! NewToy!!!!!! ROFL ROFL Thanks, Chris Link to comment https://www.classiczcars.com/forums/topic/8035-drive-shaft/ Share on other sites More sharing options...
September 22, 200321 yr comment_50578 Slip yoke on the front.. all you need are the basic box end wrenches to pull the shaft.. better to take a good selection from 10mm all the way to 17mm just in case you find something else that needs "adjustment".. one second thought, better to take two of 14mm and 15mm.. I've seen some cars that had different sized nuts on the flanges... Link to comment https://www.classiczcars.com/forums/topic/8035-drive-shaft/#findComment-50578 Share on other sites More sharing options...
