Posted September 26, 200321 yr comment_50979 Can anyone tell me the correct diameter of fuel hose to use from the fuel rail to the Round Top SU's on a 1972 240Z? Is it 5/16" (which seems a little too big) or 1/4" (which seems a bit small)? Thanks!Carl Link to comment https://www.classiczcars.com/forums/topic/8093-fuel-hose-diameter-for-sus/ Share on other sites More sharing options...
September 26, 200321 yr comment_51009 It's either 4 or 6 mm ID, Carl. You can tell by the size of the nipple. One is small and the other is large. I can't remember between the two, but the fuel pump takes the larger 6mm. Link to comment https://www.classiczcars.com/forums/topic/8093-fuel-hose-diameter-for-sus/#findComment-51009 Share on other sites More sharing options...
September 26, 200321 yr Author comment_51011 Originally posted by 26th-Z It's either 4 or 6 mm ID, Carl. You can tell by the size of the nipple. One is small and the other is large. I can't remember between the two, but the fuel pump takes the larger 6mm. Thanks. I doubt it makes much difference between the two, ( nobody sweats the details like Carl) but I wanted to try to get everything as close as possible to the optimum. Link to comment https://www.classiczcars.com/forums/topic/8093-fuel-hose-diameter-for-sus/#findComment-51011 Share on other sites More sharing options...
September 26, 200321 yr comment_51015 Hi Carl,This weekend I just got done taking off the rubber 5/16" fuel lines to the SUs that came with the car and changed it to 5/16" braided stainless lines. It fit just fine. Now with the air vent fittings on top of the SUs, they're a little bigger. With the extra 5/16" stainless line I had left over I did these vent lines in stainless too, but it was a tighter fit...but did em too.later. Link to comment https://www.classiczcars.com/forums/topic/8093-fuel-hose-diameter-for-sus/#findComment-51015 Share on other sites More sharing options...
