Shine on
Victor Laury
It's a comb set of the DeWalt polishing machine, a velcro backing disc, a wool bonnet, 2 foam bonnets and the "system 1 polish". Basicaly, the polish uses the different cutting action carectaristics of the bonnets for the buff and polish. The wool is more aggresive, so it's the first step to cut down the scratches. Then the foam is more gentle and used for the polish stage.
I could have done a better job, as I was too freaked about cutting too far. But carefull is better than cutting down to primer anyday!
No Keith, That's the Cheap arse respray the P.O. did (may he rot in hell). oy! OY! you should see when I took off the bumpers! OY VEY GAVAULT! what a mess! That's why I get a kick when someone describes my car as "Clean". Heaven forbid they should look closer! If I go fast enough, the car looks perfect!
Hmm, your car had a PO just like mine did then..... didn't take of the bumpers, or any of the trim when changing the color.. at least yours is close to the same color.. mine went from silver to, well, I'm not sure what color it really is but it ain't silver....:cross-eye
Originally posted by 1975yellowBSPZ
"And his suble use of overspray was an artistic marvel..."
I nearly hit the floor with that one :).
What is it with Silver Z's? Mine was once silver now red.
It just seems everyone goes from Silver to something else.
I really like my friends Silver 240z he did the rear light panel in chrome looks interesting indeed.
