JMT240KGTR Posted October 2, 2003 Share #1 Posted October 2, 2003 Just like some feedback on the build up below.Note I've built an L6 before, (converted L24 to L26 specs, cammed, high comp, usual mods etc), and also had a 260Z with high comp L28, 240 carbs, Holinger 5 speed etc etc.Both engines were very powerful, and responded differently to varying situations. I liked the revving of the L24/26 over the 2.8.What I'm going down the route of now is re-building an L24 with pretty much the same formula as the two previous builds and that is:-L24 crank/rods (std)L24 bore (std)Head shaved .060" E88 42mm inlet & 33mm exhaust valves (std)Elec distributor & coil to suitEx-turbo L28 oil pump240Z Su'sCamshaft ? to be determinedExtractorsC/R should be in the high 9's ie 9.8-9.9:1 Driveline C110 5 speed3.9 R180 diffMind you I like and prefer the 2.8 buildup, but since I hadn't done a 2.4 before I'm going to give this a shot.Anyone done a similar build up with a 2.4? How does it sound? Recommendations on the cam? Anything? I want to see what I can extract from the smaller of the L6s, if you guys know, bring it on!James Link to comment Share on other sites More sharing options...
Ben Posted October 2, 2003 Share #2 Posted October 2, 2003 I recommend that you fit 35 & 44mm valves.Most power gains in the L engines are in head work & the valve sizes are one area that it's easy to improve on. Link to comment Share on other sites More sharing options...
