Posted October 2, 200321 yr comment_51755 I was looking to remove my carburetors for a rebuild. I have a friend who can help me rebuild them and show me a few things about carbs. Only problem is I have to go to him to do so. Since my Z is not on the road yet, so I would remove the carbs for this.I looked in the Haynes manual and they had no info on actually taking them out that I seen (granted I looked quick today before work). I was wondering if it was in the book "How to rebuild your OHC engine" or whatever the title is close to that. I am waiting for it to come in still to my local store on order.So basicly I am wondering if it is not in there are there any other places you would reccomend looking to for removal or any of you have any input to add into this?SuDZ Link to comment https://www.classiczcars.com/forums/topic/8188-removing-the-carbs/ Share on other sites More sharing options...
October 2, 200321 yr comment_51758 Assuming you're talking about standard SU carbs there's really not much to it. As I recall the only tricky part is if you have the water line attached. In that case you may want to drain the coolant some first. As always just remember how (or take pictures) to get it back together properly. Link to comment https://www.classiczcars.com/forums/topic/8188-removing-the-carbs/#findComment-51758 Share on other sites More sharing options...
October 2, 200321 yr comment_51761 The book that you mentioned will tell you all about the ENGINE itself, but will not help you with the carbs. Get a Haynes manual and/or a Nissan FSM (Factory Service Manual)Removing the carbs is fairly simple.You drain the cooling system about half way, then disconnect:the air cleaner housingvac hose from the distributortwo fuel hosesthe throttle linkage operating rod4 nuts & washers on each carb Link to comment https://www.classiczcars.com/forums/topic/8188-removing-the-carbs/#findComment-51761 Share on other sites More sharing options...
October 2, 200321 yr Author comment_51767 Alright sounds like it will go pretty well then. I will make it a project for my little brother to help me out with tommorow. ThanksSuDZ Link to comment https://www.classiczcars.com/forums/topic/8188-removing-the-carbs/#findComment-51767 Share on other sites More sharing options...
