I am having all new carpet installed but I have one major problem.
Water is leaking onto the passenger floorboard. Under the dash.
I disconnected the hose from the blower motor and I have major rust where it connects under the dash.
I am trying to avoid having to remove the entire dash. I removed the cowl under the wipers which is not much help in getting to the area that needs to be fixed.
any suggestions? quickest way to take the dash out?
https://www.classiczcars.com/forums/topic/8210-water-leak/
See all of the recent posts from those of us getting our dashboards repaired. It's not too hard to pull the dash. The only tedious part is remembering how everything connected. I was in a hurry when I did mine and it took a little work to get it back in and everything connected up properly.
https://www.classiczcars.com/forums/topic/8210-water-leak/#findComment-51931
