hello gentlemen,
does anyone have the magic tech app for the poly urethane rear control arm bushing "squeak".
i have greased the bushings with bearing grease which has diminished the problem. i have not been able to elimate the issue. it is worse in lower, below 50 degrees, temp...
thanks
keith
https://www.classiczcars.com/forums/topic/8242-poly-urethane-bushing-squeak/
