Posted October 10, 200321 yr comment_52651 Without a doubt I'm going with Konig Monsoon rims on my Z. I was just wondering for those of you with 16x7" rims, what offset should the rims be? Most of the Monsoon rims I've seen have a 40mm offset. Link to comment https://www.classiczcars.com/forums/topic/8315-offset-spacing/ Share on other sites More sharing options...
October 10, 200321 yr comment_52656 You may want to check and confirm this, but my understanding is that for proper geometry you need ZERO off set. I believe you're going to need spacers if you use those wheels in order to get it set up properly. Link to comment https://www.classiczcars.com/forums/topic/8315-offset-spacing/#findComment-52656 Share on other sites More sharing options...
October 11, 200321 yr comment_52783 He is right you need spacers. Also you may want to reconsider those monsoon wheels are tanks and will slow your car down Link to comment https://www.classiczcars.com/forums/topic/8315-offset-spacing/#findComment-52783 Share on other sites More sharing options...
