blitzkraig Posted October 10, 2003 Share #1 Posted October 10, 2003 Without a doubt I'm going with Konig Monsoon rims on my Z. I was just wondering for those of you with 16x7" rims, what offset should the rims be? Most of the Monsoon rims I've seen have a 40mm offset. Link to comment Share on other sites More sharing options...
Bambikiller240 Posted October 10, 2003 Share #2 Posted October 10, 2003 You may want to check and confirm this, but my understanding is that for proper geometry you need ZERO off set. I believe you're going to need spacers if you use those wheels in order to get it set up properly. Link to comment Share on other sites More sharing options...
Wicked C5 Posted October 11, 2003 Share #3 Posted October 11, 2003 He is right you need spacers. Also you may want to reconsider those monsoon wheels are tanks and will slow your car down Link to comment Share on other sites More sharing options...
