differential help please
Dreco
would play in bearings result in a louder rear end?? and would play in bearings lead to premature failure. just to make it clear, I'm refering to the 2 side flanges that insert into the R200. Is there any difference between the ones from a early model R200(1976) and a late R200(1981). I wondered if something was wrong with the input shafts of the flanges. the play is up and down. what would cause that type of play?? It seems to be worse on the passenger side than the driver side.
  • Who's Online   2 Members, 0 Anonymous, 561 Guests (See full list)
