November 14, 200321 yr Author comment_56992 I learnt a few lessons last night... 1. Really sideways zed with an open diff=unpredictable. 3. Sitting on top of the rear axle throws you around a bit when it does hook up. 2. Zed with $^!# tires = like ice skating, in the wet. I'm also finding that even with these shitty tires I'm getting a decent amount of body roll in the corners. Around 90 deg bends it'll unweight the inside rear and spin it up......well either that or go sideways. I haven't played with tire pressures yet. I'll have to check them next time I take it out. Link to comment https://www.classiczcars.com/forums/topic/8352-max-tire-width-on-7-rim-on-front-of-260z/?&page=2#findComment-56992 Share on other sites More sharing options...
November 15, 200321 yr comment_57179 A lot of that spookiness and excessive roll is often due to worn out bushings, bad shocks, or both. All of the negative tendencies of the Z are compounded greatly if thats the case. Have you replaced any of the rubber bushings with poly? Link to comment https://www.classiczcars.com/forums/topic/8352-max-tire-width-on-7-rim-on-front-of-260z/?&page=2#findComment-57179 Share on other sites More sharing options...
November 15, 200321 yr Author comment_57210 New shocks and springs all round. Mustache bar bushes have been replaced, but none of the other major ones in the rear end. A few in the front end have been done.Another question: I get a fair bit of bump steer in my zed.....eg I'll be coming around a corner and I hit some bumps in the road, and they will turn the steering wheel. Again, sometimes not the most confidence inspiring feeling. Anyone else get this? Is it normal for a zed? Link to comment https://www.classiczcars.com/forums/topic/8352-max-tire-width-on-7-rim-on-front-of-260z/?&page=2#findComment-57210 Share on other sites More sharing options...
November 16, 200321 yr comment_57213 I think what you are describing as bumpsteer is just in fact steering feedback. Bump steer as I understand it is when the suspension compresses, the angle of the wheel changes, so the steering wheel itself stays the same, but the angle of the front wheel changes. Is just holding the wheel tighter an option, or is it a serious problem? Link to comment https://www.classiczcars.com/forums/topic/8352-max-tire-width-on-7-rim-on-front-of-260z/?&page=2#findComment-57213 Share on other sites More sharing options...
November 16, 200321 yr Author comment_57215 Yeah your right. It'd be steering feedback, not bump steer.It's not really that bad that it's a problem, just means you have to have a firm grip on the wheel. I'm just wondering if this is normal on zeds or not? Link to comment https://www.classiczcars.com/forums/topic/8352-max-tire-width-on-7-rim-on-front-of-260z/?&page=2#findComment-57215 Share on other sites More sharing options...
