Posted October 13, 200321 yr comment_53009 What would cause the ignition to not shut off when in the OFF or LOCK position?the battery's-a-draining.....HELP!! Link to comment https://www.classiczcars.com/forums/topic/8360-240z-ignition-problem/ Share on other sites More sharing options...
October 14, 200321 yr comment_53062 Bad ignition switch? I dunno, electrical drives me nuts:tapemouth Link to comment https://www.classiczcars.com/forums/topic/8360-240z-ignition-problem/#findComment-53062 Share on other sites More sharing options...
October 14, 200321 yr comment_53067 Have you been doing anything with the wireing? you either have a bad ignition switch , as blitz said , or have cross wired the ignition. Link to comment https://www.classiczcars.com/forums/topic/8360-240z-ignition-problem/#findComment-53067 Share on other sites More sharing options...
