Piston disassembly
blitzkraig
So I've got a broken needle stuck in a piston and I can't get it out. Seeing as my new SM needles were fairly loose in the piston I think I need to replace that little metal cylinder that the needle is placed and screwed into. Anyone know how to get it out? I'm thinking it needs to be pressed up into the piston and out?
I ordered new main jets and needles for my 4 screw carbs from Z therapy. The new SM needles would go in loose and when I tightened them down they went cockeyed so the piston would stick. So I had a rebuild kit laying around with spare needles made by someone else and I stuck them in (they don't go in very easily). Anyway, got the needle in one but the second one snapped off with the base still in the piston.
Did you compare the base diameter of the old & new needles? Some where in the past 30 years the pistons may have seen some activity to damage the holes so good needles will not secure right. ZT has refurbished matched domes & pistons. Have you tried rusted-nut-buster spray, or maybe heating up the area around the broken needle to loosen the fit. Don't know if the metal would expand enough to let go? They freeze motor parts or sleeves and what not to before pressing together, so. . . aaaa
I don't know. Well I guess reach for your oriental friend- Mr. Wallet-San.
:ermm:
