Posted October 17, 200321 yr comment_53437 I've got my 260z on stands and have undone most of the bolts...How do my new poly front control arm bushes go in..??Is there any benifit to put them in back to front..ie to increase caster/camber etc??????It looks lkike the "thicker" side goes to the back...but again, is it worthwhile puitting them in backwards???any ideas ??? Link to comment https://www.classiczcars.com/forums/topic/8420-control-arm-busheswhich-way-do-they-go-in/ Share on other sites More sharing options...
October 17, 200321 yr comment_53445 they should be labelled mine were with an indications as to which one faced the front of the car and which one faced the back. They are a bastard to install and i would highly recommend having the old ones pressed out and new ones pressed in. The car feels alot better if your old bushes were worn when you replace them . Link to comment https://www.classiczcars.com/forums/topic/8420-control-arm-busheswhich-way-do-they-go-in/#findComment-53445 Share on other sites More sharing options...
