will head fit?
echocluster
If you have a turbo engine, you won't have to worry about the compression. The turbo engines have dished pistons and the compression will probably be more in the neighborhood of 9:1 with an E-31. No problems.
According to the engine calculator, your compression should come in somewhere between 8-8.75:1 depending on which head gasket you use.
Before you get too excited, which head is on the Turbo? The P90?
The P-90 is already one of the best flowing heads due to it's being used with the Turbo, so if you are keeping th FI and Turbo, the E-31 won't help you much, if at all.
Plus, with the Turbo, you're gonna run into trouble with detonation at 9:1 more than likely. 9:1 is right on the borderline with a Turbo. Which means even more work and money.
You might be better off to spend your money on an intercooler.
:ermm:
The E-31 is an early 240Z head, NA and will produce probably the highest compression ratios available using a stock head.
Around the block,
Hmmmmm, pull it out of the driveway, kick it in the A$$ and call a tow truck to get home....
  • Who's Online   3 Members, 0 Anonymous, 794 Guests (See full list)
