will 240z struts/and or springs go into a 260z 2+2?
datfreak
Actually...Koni is no selling their strut inserts as being for 70-78 vehicles. All with the same part number...so yes struts for a 240 will fit into a 260 2+2....as for springs...you definitely need to be aplication specific because of the increased weight of a 260 2+2
Hmm, 280 strut housings are 5mm larger diameter and a bit longer than a 240, wonder if Koni is "making" them fit like Zvoiture's Tokiko's?
As far as the 2+2 springs are concerned, you would have to cut them as they are stiffer and longer than the 240 springs and will give your car the 4x4 look, I know, I tried it many years ago trying to spend as little money as possible. I never bothered to cut the ones I had to get the car back to where it should have been, I just yanked them off and bought proper lowering springs.:ermm:
  • Who's Online   2 Members, 0 Anonymous, 354 Guests (See full list)
