Kill-switch
SCCA_racer
I am upgrading my race car from a 2 pole to a 4 pole kill-switch. The switch comes with diagrams for a one wire or a field alternator style of installation. Difference being that one breaks the connection from the field wire to the positive pole of the battery with its auxiliary terminals while the charge wire is interrupted by the break in the main fuse block. The other interrupts the charge wire to positive pole only and omits the field wire. Am I missing out and this is just showing me how two different alternators will be wired? It would appear if this is the case that I need the field wire style. Am I right? There are two diagrams but NO instructions or explanations with this thing and I don't want to ruin anything or burn up my car before I get it back on the track. I have attached a pic of the diagrams.
Thanks
Bryan
I agree it looks like they didn't give much install help.I can't read many words on the attachment.Perhaps a larger photo of the configuration you have would help.Why do you need four kill locations?Also what is the volt/amp rating on the 4pole switch?
The switch has 4 terminals, not positions. One set is for killing the battery one set is for killing the alternator. The switch is rated for the application. I forget, but the peak load rating is ridiculous.
If you use an applciation that allows you to zoom in, the image is legible.
thanks for trying,
Bryan
