Posted October 21, 200321 yr comment_54041 looking for a Weber set-up as SU's may not flow enough, aftermarket 240mm flywheel, new pistons, turbo head and turbo block, and some used 240 rods with larger 9mm bolts.Have crank and an idea!Rick Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/ Share on other sites More sharing options...
October 22, 200321 yr comment_54235 I have an F54 block, 240 connecting rods and a P90A (non-hydraulic) head, but I am in Phoenix AZ. Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-54235 Share on other sites More sharing options...
October 23, 200321 yr comment_54282 I have a brand new set of Weber 45 in the box w/ TWM manifold already ported with all new linkage . I was wondering are you sure you wanna go turbo or N/A with this carb setup . I have a complete head ( assembled , lashed , w/performance cam and headwork ) with lots of work , JE pistons and everything to complete this setup . Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-54282 Share on other sites More sharing options...
October 28, 200321 yr comment_54903 I have the following parts available for your project:FOR SALE: SIX OF NISSAN PART NUMBER 12033-83W01. 89MM STD pistons and pins. Retail price is $300.60 through your local Nissan dealership. ONE OF NISSAN PART NUMBER 12033-13G10. 89MM ring set to complete four pistons. Retail price is $99.76 through your local Nissan dealership. These parts are new and stored inside their factory packages. I am asking $115 for everything and at this price I will pay the cost of shipping within the continental United States. Pictures are available upon request. Parts are available to be previewed in Houston, TX. Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-54903 Share on other sites More sharing options...
October 28, 200321 yr Author comment_55010 FOR SALE: SIX OF NISSAN PART NUMBER 12033-83W01. 89MM STD pistons and pins. Retail price is $300.60 through your local Nissan dealership. ONE OF NISSAN PART NUMBER 12033-13G10. 89MM ring set to complete four pistons. Retail price is $99.76 through your local Nissan dealership. These parts are new and stored inside their factory packages. I am asking $115 for everything and at this price I will pay the cost of shipping within the continental United States. Pictures are available upon request. Parts are available to be previewed in Houston, TX. The 3.1 litre engine looks doable, but the Webbers look like a disaster. I wish this was R & D'd and there was base line for the jetting. The SU's work so well, even with modifications on the 240, I'm thinking 280 short block, P-90 head, Racer Brown cam, and SU's.Any ideas on the 3.1 stroker as I have that nice crank froma bad injector Maxima?Rick Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55010 Share on other sites More sharing options...
October 28, 200321 yr comment_55024 I'm confused by your reply. I have pistons, pins, and rings that will help you build a 3.1 L stroker motor using an L28 block. Combine these parts with the Maxima crank and L24 rods and you will have a motor with 3098cc displacement. Combine these parts with a P90 head and the engine's compression ratio is 8.14 (plenty of low rpm,snap your head back torque). Check out www.zcluboftexas.org/l28combo.html for more information regarding L28 bore and stroke combinations. Also check out www.hybridz.org for information from people that have already performed this kind of engine build. The best advice I can give you - buy my parts! Let's make a deal! Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55024 Share on other sites More sharing options...
October 28, 200321 yr comment_55029 So $115 for the parts shipped? I guess my only question is why the discount? I mean I'm interested but anytime something looks too good to be true it usually is something else.... Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55029 Share on other sites More sharing options...
October 28, 200321 yr comment_55036 Hmmmm, checked out the club of texas site, they list the pistons as 12012-83W01 not 12033-83W01.... Low price = don't work?.... no offence but you are rather new here and pushing your wares pretty hard... Is there a difference in pin height between 12012 and 12033? Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55036 Share on other sites More sharing options...
October 29, 200321 yr comment_55127 There is no trickery here. I am not a majician, just someone that has a hard time typing the correct part numbers for the items he has for sale. The part numbers for the items I have are 12010-83W01 for the pistons and pins and 12033-13G10 for the ring set. These are the part numbers on the original Nissan boxes. I can provide you with pictures if you need verification.These parts are listed on the Z Club of Texas website in their L28 bore and stroke combination guideline. I used this information when I originally purchased these parts from an engine builder in California. I am not looking to make a profit from this sale. I am in a situation where I am selling my project parts and eventually my project car.Please let me know if your are still interested in making a purchase. I'm sorry for the confusion in my earlier post. Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55127 Share on other sites More sharing options...
October 29, 200321 yr comment_55128 Here is the link again for reference:http://www.zcluboftexas.org/128combo.html Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55128 Share on other sites More sharing options...
October 29, 200321 yr comment_55129 "Hmmmm, checked out the club of texas site, they list the pistons as 12012-83W01 not 12033-83W01...."For the record, all the piston part numbers on the Z Club of Texas website have the prefix 12010. Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55129 Share on other sites More sharing options...
October 29, 200321 yr Author comment_55140 Originally posted by thedvlsh1 "Hmmmm, checked out the club of texas site, they list the pistons as 12012-83W01 not 12033-83W01...."For the record, all the piston part numbers on the Z Club of Texas website have the prefix 12010. These pistons seem to be dished and I'd never run a Turbo charger. Back in the day, Bob Sharpe would say my car had no compression as it was 9:00 to 1 and too low for his liking!It ran 120's on the straight aways bone stock, with a 5 speed, gears and a cam and kit it ran 130's with a stock short block. If I redo this project I'll go 10.5 on the compression, 94 octane is always available back East. Will the E-31 head with big vlaves flow like a P90 Head? Just thinking about uping the compression on that F-54 short block? Rick Link to comment https://www.classiczcars.com/forums/topic/8492-31-stroker-parts-webbers/#findComment-55140 Share on other sites More sharing options...
