November 18, 200321 yr comment_57540 Originally posted by baddriver This is Oversteer, and the fix is to turn the car Less into the turn. No no no! You've got it all wrong. Hook into the corner harder, then apply LOTS of oppy lock. Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57540 Share on other sites More sharing options...
November 18, 200321 yr comment_57542 Originally posted by baddriver neutral steer, with just a little bit over or under Anyone want to start a discussion on slip angles in a Z?steve77 Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57542 Share on other sites More sharing options...
November 18, 200321 yr comment_57544 Zvoiture: Go for it.....or has it already been covered in some old threads? Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57544 Share on other sites More sharing options...
November 19, 200321 yr comment_57558 Yes, lets hear about slip angles. Speaking of which don't believe anyone who says that Zeds understeer, oversteer or whatever. They can be set up to do just about anything you want, its all about body stiffness, weight distribution, wheel alignment settings, springs, shocks and sway bars. Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57558 Share on other sites More sharing options...
November 19, 200321 yr comment_57560 ...and how you drive it. Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57560 Share on other sites More sharing options...
November 19, 200321 yr comment_57575 ...not to mention the drive-type!The Z was sooo easy to 'get the back out' (oversteering), of course I only did it when it was safe :classic: but boy do I miss it... The K with 30 year old suspension, 20 less horses, 300kg more and a slushbox doesn't quite do it the same............. Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57575 Share on other sites More sharing options...
November 22, 200321 yr comment_57962 in stock form, the Z is set up to understeer through the corner, as most cars are. This is easily remedied with a thicker rear sway or stiffer springs. to the guy running l28et and 4.3 gears: you may not like that gearing very much because you'll run out of gear before you reach full boost! Link to comment https://www.classiczcars.com/forums/topic/8515-oversteerundersteer/?&page=2#findComment-57962 Share on other sites More sharing options...
