Gas filling up air cleaner
sahunt66
Hello,
I have a '71 240Z. The car sat several years in a my father's garage. I started it up and it runs fine except gas filled up the bottom of the air cleaner while it was running. What causes this? Should I take the carbs off and rebuild them? Or just use carb cleaner or something? What's a good source for a rebuild kit if I need to do that?
I'm new to z-cars and have limited experience in mechanics; but I've done breaks, tune-ups, etc...
Thanks!
Yeah 2mz's is on target.The fuel overflows from the hose on the top of the carb bowls that attach to the air cleaner.Find the wet hose and you know your problem.If you have the drain on the side of the bowl that may get the trash out.I have had luck tapping the carb bowl with the rubber handle end of a screwdriver.DO iT EASY!! That pot metal will crack.Trash seems to be the problem.If the lines aren't clean a rebuild will buy you nothing.
  • Who's Online   2 Members, 0 Anonymous, 557 Guests (See full list)
