1978 280z
Head is back from the machine shop ( e88 head all new 280 valves and springs, hot cam)
Arizona intake with a holley 390.
MS square port header
I am going to be putting it all back together this weekend.
I am interested pinning the dizzy at full advance......How do I do this?
I can see how to pin the vacuum advance with a small machine screw but doesnt this car also have a mechanical advance?
If so how do I pin it?
Do I need to remove the entire dist. to do this?
How many degrees of advance do I need to set it at while at 3k rpm?
What type of performance gains can you get by doing this?
Thanx in Advance
Jeff
