AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into
compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Hiroshima, Japan, and rounds them off.
AVIATION METAL SNIPS: See hacksaw.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring
sulfuric acid from a car battery to the inside of your toolbox
after determining that your battery is dead as a doornail, just
as you thought.
CRAFTSMAN ½ x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
DRILL PRESS: A tall upright machine useful for suddenly snatching
flat metal bar stock out of your hands so that it smacks you in
the chest and flings your beer across the room, splattering it
against the Rolling Stones poster over the bench grinder.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets
in their holes until you die of old age, but it also works great
for drilling rollbar mounting holes in the floor of a sports car
just above the brake line that goes to the rear axle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
holes and is ten times harder than any known drill bit.
HACKSAW: One of a family of cutting tools built on the Ouija
board principle. It transforms human energy into a crooked,
unpredictable motion, and the more you attempt to influence its
course, the more dismal your future becomes.
HAMMER: Originally employed as a weapon of war, the hammer
nowadays is used as a kind of divining rod to locate expensive
car parts not far from the object we are trying to hit.
HYDRAULIC FLOOR JACK: Used for lowering a Datsun to the ground after you have installed a set of NISMO lowered road
springs, trapping the jack handle firmly under the front air dam.
MECHANIC’S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works
particularly well on boxes containing convertible tops or tonneau
covers.
OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the tool box.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round-out Phillips screw heads.
PHONE: Tool for calling your neighbor Chris to see if he has
another hydraulic floor jack.
PLIERS: Used to round off bolt heads.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
TIMING LIGHT: A stroboscopic instrument for illuminating grease
buildup on crankshaft pulleys.
TROUBLE LIGHT: The mechanic’s own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, “the sunshine
vitamin,” which is not otherwise found under cars at night.
Health benefits aside, its main purpose is to consume 40-watt
light bulbs at about the same rate that 105-mm howitzer shells
might be used during, say, the first few hours of the Battle of
the Bulge. More often dark than light, its name is somewhat
misleading.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
tensile strength of ground straps and hydraulic clutch lines you
may have forgotten to disconnect.
VISE-GRIPS: Used to round off bolt heads. If nothing else is
available, they can also be used to transfer intense welding heat
to the palm of your hand.
WIRE WHEEL: Cleans rust off old bolts and then throws them
somewhere under the workbench with the speed of light. Also
removes fingerprint whorls and hard-earned guitar callouses in
about the time it takes you to say, “Django Reinhardt.”
https://www.classiczcars.com/forums/topic/8608-my-tools-explained/
