26th-Z Posted October 28, 2003 Share #1 Posted October 28, 2003 AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it intocompressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Hiroshima, Japan, and rounds them off.AVIATION METAL SNIPS: See hacksaw.BATTERY ELECTROLYTE TESTER: A handy tool for transferringsulfuric acid from a car battery to the inside of your toolboxafter determining that your battery is dead as a doornail, justas you thought.CRAFTSMAN ½ x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.DRILL PRESS: A tall upright machine useful for suddenly snatchingflat metal bar stock out of your hands so that it smacks you inthe chest and flings your beer across the room, splattering itagainst the Rolling Stones poster over the bench grinder.EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivetsin their holes until you die of old age, but it also works greatfor drilling rollbar mounting holes in the floor of a sports carjust above the brake line that goes to the rear axle.E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in boltholes and is ten times harder than any known drill bit.HACKSAW: One of a family of cutting tools built on the Ouijaboard principle. It transforms human energy into a crooked,unpredictable motion, and the more you attempt to influence itscourse, the more dismal your future becomes.HAMMER: Originally employed as a weapon of war, the hammernowadays is used as a kind of divining rod to locate expensivecar parts not far from the object we are trying to hit.HYDRAULIC FLOOR JACK: Used for lowering a Datsun to the ground after you have installed a set of NISMO lowered roadsprings, trapping the jack handle firmly under the front air dam.MECHANIC’S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; worksparticularly well on boxes containing convertible tops or tonneaucovers.OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the tool box.PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round-out Phillips screw heads.PHONE: Tool for calling your neighbor Chris to see if he hasanother hydraulic floor jack.PLIERS: Used to round off bolt heads.SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.TIMING LIGHT: A stroboscopic instrument for illuminating greasebuildup on crankshaft pulleys.TROUBLE LIGHT: The mechanic’s own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, “the sunshinevitamin,†which is not otherwise found under cars at night.Health benefits aside, its main purpose is to consume 40-wattlight bulbs at about the same rate that 105-mm howitzer shellsmight be used during, say, the first few hours of the Battle ofthe Bulge. More often dark than light, its name is somewhatmisleading. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing thetensile strength of ground straps and hydraulic clutch lines youmay have forgotten to disconnect.VISE-GRIPS: Used to round off bolt heads. If nothing else isavailable, they can also be used to transfer intense welding heatto the palm of your hand.WIRE WHEEL: Cleans rust off old bolts and then throws themsomewhere under the workbench with the speed of light. Alsoremoves fingerprint whorls and hard-earned guitar callouses inabout the time it takes you to say, “Django Reinhardt.†Link to comment https://www.classiczcars.com/forums/topic/8608-my-tools-explained/ Share on other sites More sharing options...
LanceM Posted October 28, 2003 Share #2 Posted October 28, 2003 Saw this on one of the antique tractor forums I frequent but couldn't find it to post here later. If this dosen't discribe tools and their common useage I don't know what does Link to comment https://www.classiczcars.com/forums/topic/8608-my-tools-explained/#findComment-55030 Share on other sites More sharing options...
Shaddow Edge Posted October 31, 2003 Share #3 Posted October 31, 2003 I think I cried with laughter when I read that. My flat mate loved it as well. Link to comment https://www.classiczcars.com/forums/topic/8608-my-tools-explained/#findComment-55367 Share on other sites More sharing options...
tanny Posted October 31, 2003 Share #4 Posted October 31, 2003 Really sorry bud that you have a flat mate. Better get over to the Boobs thread. Victor.:cheeky: Link to comment https://www.classiczcars.com/forums/topic/8608-my-tools-explained/#findComment-55412 Share on other sites More sharing options...
