http://home.stny.rr.com/nuclearmonkey/pics/mini-IMG_0438.jpg
http://home.stny.rr.com/nuclearmonkey/pics/mini-IMG_0444.jpg
I have the following setup for sale:
Much desirable Maxima caliper bracket
82-83 280zx Calipers
Early Z31 rear disk brakes re-drilled for 4 bolts (or could be used with original 5 bolt holes)
AFAIK Setup is in good working order, only slight surface rust on rotors, actual rotor surface is clean and smooth
Should be everything need to convert a Z to rear disk brakes, even include the anti-rattle clips.
I'm looking for $370 shipped for the setup (shipping would run $40-$50)
Awsome deal on 71 240z w/ 383 stroker has come up, and of course, I'm a couple bucks short! Open to offers, or just suggestions on price. Like I said, I need to sell QUICK!
jmead@stny.rr.com
Originally posted by jamesblack
question, could i keep my front discs that are on my 240z and just swap the drums for these ones, im a newb :P
yeah, that is what this kit is. You use whatever setup you've got on the front, and then this kit replaces the stock rear brakes with disks.
