Posted November 2, 200321 yr comment_55536 I am looking for the brake tubing that goes from the master cylinder to the brake switch for a 72-72 240. I am wanting to put a later model Master on my 70, and it requires different tubing. Aybody?? Link to comment https://www.classiczcars.com/forums/topic/8675-wtb-brake-tubing/ Share on other sites More sharing options...
November 2, 200321 yr comment_55537 You want new or used? I've got a 72 you can have the brake lines off.. free.. if you come and take them off. I'm not delivering to Kuwait that's for sure..... Maybe Chloe can tell us if the new ones are still available.... Link to comment https://www.classiczcars.com/forums/topic/8675-wtb-brake-tubing/#findComment-55537 Share on other sites More sharing options...
November 2, 200321 yr Author comment_55573 used would work just fine....just gives me another reason to go down to Virginia.. I dont think those lines have been available for some time, but it is worth asking. Link to comment https://www.classiczcars.com/forums/topic/8675-wtb-brake-tubing/#findComment-55573 Share on other sites More sharing options...
November 2, 200321 yr comment_55593 Looking through my notes I came up with the brake lineto pressure differential warning light switch. I did the ZXmaster cylinder swap on my 71 and was going to order acouple of these but found some used ones that I made work. If you get them let me know if they were correct.Part #: 46241-E4601 List: $4.64 Link to comment https://www.classiczcars.com/forums/topic/8675-wtb-brake-tubing/#findComment-55593 Share on other sites More sharing options...
