Turn Signals....
Xargon321
well i just put a Radio in my car and got it all together and looking good, now my turn signals dont work, hazards do, headlights high and low beam work, changed the flasher unit with another one and still no dice, it worked the night before when i put it in the garage.....
My understanding is that the Hazards have a different "flasher unit", so I assume tha they are on a different circuit. Do your brake, and/or tail lights work? I think that they are on the same circuit as the signals, since they use the same bulbs.
EDIT: :stupid: Err, wait a minute, the Hazzard's use those bulbs too, but as Zs-ondabrain indicates below one circuit is switched and the other is not. Guess I shouldn't type when sleepy
Not neccessarily Xargon, the hazzards work wether the ignition is on or not,
the turn signals only work if the ignition is on.
therefor, that leads me to believe that they run off of two different power sources, a constant and a switched.
like bambikiller said, "check yer fuses" use an ohms meter on them to be sure. or find a new fuse and replace the fuse in question.
little known fact is, fuses don't always blow where the glass is, some fuses blow within the metal end caps and look "good" to the obvious onlooker, always test em
"The voltmeter is our friend"!!!:classic:
good luck,
Dave.
MAKE SURE YOUR HAZARD FLASHER SWITCH IS ALL THE WAY OFF!!!! TURN IT ON AND OFF A FEW TIMES THEN CHECK YOUR SIGNALS. These switches can hang up in between on and off. If it is not completely off the signals will not work. The power to the signals goes through the hazard switch.
Well Fuse isent the culpret, change my hazard switch with one i got out of a old console, had it for a sec but then quit, Pulled the turn signal switch, and the ground wire for the head lamps falls off... resolder that got it back together, also got my horn working again as the contact wasent making contact with the horn pad...
i cant tell if its the turn signal switch or the hazard switch. will check in a min to see if console harness is plugged in all the way with the main harness
Need More help, i think its the hazard switch if i turn them on, then turn them off and hit the turn signal switch the flasher unit click once or twice but wont turn the lamps on, im sure that its the turn signal flasher clicking cause i had ahold of it and felt it click
Try getting a schematic so you can trace it. Change the flasher if you haven't already. Get the schematic somewhere in this forum....do a search. I don't know if the CD sold here has it. Or buy a cheap manual..none of them are very good but may help.
  • Who's Online   2 Members, 0 Anonymous, 983 Guests (See full list)
