Posted February 6, 200223 yr comment_2761 Is there an initial setting that the Carburetor Idle Adjust Screw should be set at prior to balancing the carburetors? I'm not refering to the fast idle screw, but the individual carburetor idle screws. Link to comment https://www.classiczcars.com/forums/topic/870-carburetor-idle-adjust-screw/ Share on other sites More sharing options...
February 6, 200223 yr comment_2763 Haynes says to seat them then back off about 3/4 turn. Link to comment https://www.classiczcars.com/forums/topic/870-carburetor-idle-adjust-screw/#findComment-2763 Share on other sites More sharing options...
