Clutch Slave Cylinder
SuDZ
No, I didn't say the Russel Speed Bleeder is $5. SDomeone else said the bought a different kind of bleed device for $5.
As I recall, the Russell Speed Blleders come 2 to a package and you only need one for the Clutch Slave, but the other could be used in your rear brake cylinder or kept for a spare. I think they cost around $15. What they are is a replacement for the blled screw in the cylinder that has a one way check valve tha when you loosen automatically allows you to pump air out of the lines without allowing air back in. SO, you simply loosen the Speed Bleeder and pump the pedal by hand while looking to see that no more air comes out of the bleeder. When nothing but fluid comes out, you go around and tighten the bleeder and you are done. Makes it a one man job and stays with the cylinder so you can do it again next time you need to bleed for whatever reason.
Check out this website for info on Speed Bleeders You can find Part Number and Where to buy (if you are interested)
The one you would want is for Rear brakes of 69 to 78 Z Car (same fitting is used for clutch slave cylinder.)
