August 29, 200420 yr comment_93146 That'd be a good enough reason for me to go urethane. Both inners and out outers came to under $100. If you want (probably not) the urathane pair that I pulled out of my car (which are in perfect condition), they're all yours. Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-93146 Share on other sites More sharing options...
August 31, 200420 yr comment_93428 One more quick observation that I never noticed before, are all rear Right and Left control arms the same part, just one upside down?I never picked up on this before but its definately the case on mine.There is a dish where the pin for the sway bar mounts, so on the right and left the dish causes one side to be higher than the other, due to one being "upsidedown", does this cause the sway bar to sit on an angle? i cant remember when removing it. Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-93428 Share on other sites More sharing options...
September 1, 200420 yr comment_93450 Yeah they're the same thing but flipped on all of them. That caught me out when I was putting mine back together a few weeks ago, as I hadn't noticed when I pulled it appart.I thought that point where the sway bar mounts looked like it is still in the centre of the control arm. Mind you I didn't look too closely.Edit: Wrote the wrong bloody thing. Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-93450 Share on other sites More sharing options...
January 10, 200520 yr comment_108186 Reviving this again I have the front end out, my plan is this: Urethan bushes for: steering rack mounts steering coupler radius rods (Noltec catalogue list 2 different IDs 12.8mm and 16mm ??) OEM rubber bushes for: pivot joint between arm and crossmember **will worry about sway bars later** Also engine mount rubbers are only available from OEM I assume? ARe adjustable camber bush kits a good way to go? ( does anyone have a picture of this?) Thanks guys Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-108186 Share on other sites More sharing options...
January 11, 200520 yr comment_108273 I'm up to exactly the same stage, where are you looking at getting the bushes from?I got my rear set from Wilkinson Suspension in Perth. They were 'Noltec' brand and fit really nicely. Not cheap though, it's almost worth getting them from the US, but postage is a killer. If I was doing it again, I would get the whole set together from US.All Z is good for rubber mounts for engine and have urethane as well but are significantly more expensive.By 'radius rods' do you mean what some call compression rods?One more thing, did you re-do Tie rod ends and ball joints? If so, where did you get those?Thanks Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-108273 Share on other sites More sharing options...
January 11, 200520 yr comment_108281 One more quick observation that I never noticed before, are all rear Right and Left control arms the same part, just one upside down? I picked this up when constructing my Tamiya model kit. I was thinking "cheap bastards! these two arms are exactly the same just flipped!" until I did a bit more research (thanks kats) Clever idea huh? Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-108281 Share on other sites More sharing options...
January 11, 200520 yr comment_108335 I'm up to exactly the same stage, where are you looking at getting the bushes from?I got my rear set from Wilkinson Suspension in Perth. They were 'Noltec' brand and fit really nicely. Not cheap though, it's almost worth getting them from the US, but postage is a killer. If I was doing it again, I would get the whole set together from US. All Z is good for rubber mounts for engine and have urethane as well but are significantly more expensive. By 'radius rods' do you mean what some call compression rods? One more thing, did you re-do Tie rod ends and ball joints? If so, where did you get those? Thanks I used OEM rubber in the rear, from AllZParts, was about 30% cheaper than a Nissan dealer. I may just get the control arm and engine mounts OEM rubber and get the rest urethane, AllZParts have an adjustable camber bush kit, but I am a bit unsure whether that is the way to go or not. I beleive radius rods and tension/compression rods are the same thing. MSA have some sort of bush upgrade but I am not sure how it works I will probably get some WASP brand ball joints from AllZParts while I am ordering, $50ea. Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-108335 Share on other sites More sharing options...
February 21, 200520 yr comment_113721 Has anyone used Stewart Wilkins for suspension or parts in general?They list and adjustabel castor bush from Noltec that even Noltec does not listhttp://www.swmotorsport.com.au/suspension.htmDatsun 240/260Z Adjustable Castor Rod bushes - Noltec $29.25 Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-113721 Share on other sites More sharing options...
April 16, 200520 yr comment_120682 dragging this up againi have a clunk in the rear of me zed. there is no play in the diff etc but when i had the rear wheels in the air i could jack the diff up a couple of inches so i think the bushes are shot.looking at some of the links that have been posted in this thread i found these 'Datsun 240/260Z Diff Mount Moustache Bar bushes - Noltec $44.30' is this what i need? are there any other bushes i should replace atthe same time? Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-120682 Share on other sites More sharing options...
April 16, 200520 yr comment_120683 YOur clunk is more likely to be worn universal joints.Use the search function for an indepth explaination.MOM Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-120683 Share on other sites More sharing options...
April 16, 200520 yr comment_120686 dragging this up againi have a clunk in the rear of me zed. there is no play in the diff etc but when i had the rear wheels in the air i could jack the diff up a couple of inches so i think the bushes are shot.looking at some of the links that have been posted in this thread i found these 'Datsun 240/260Z Diff Mount Moustache Bar bushes - Noltec $44.30' is this what i need? are there any other bushes i should replace atthe same time?That is most likely caused by a rubber mount at the front of the Diff. It is quite common for the rubber to tear away from the metal of the mount and cause a "clunk" noise. Examine this area as it's a most likely defective part. Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-120686 Share on other sites More sharing options...
April 16, 200520 yr comment_120688 The front diff mount is around $90 from memory. Link to comment https://www.classiczcars.com/forums/topic/8848-suspension-questions-for-aussies/?&page=3#findComment-120688 Share on other sites More sharing options...
