Nothing...Click Click Clickity Click :(
280zx Fever
I got a 81 Zx yesterday, anyway once i hooked up the battery turn the key too the on posisiton no lights at all :( the power windows dont work but the radio works :S horn works when i go to start it it turns about 1 once maybe twice then nothing
Turn the key aroudn to start it goes click :(
So my guess is there is a electrical short somewhere but where do i check in these cars ? having not alot of direct experiance i have no idea where to check :
thanks.
I wouldn't suspect a short. Check the simple stuff first. Make sure the battery is fully charged and the battery cable connections are nice and clean, and tight. Then try it again. There can be enough there to power the radio (like you said) but not enough for the big loads like headlights, and more importantly the starter:ermm:
well i got my grand fathers Landcruiser up there got some jumper leads onto it it turns over but still no dash lights eg ones that say fuel exahust temp and seat belts...widow wipers work but the windows still dont :(
Its got a remote like a touch key arlam on the key chain but i looked around couldnt find any module for it :(
No spark....compression seems O.K seems to spin nicely over...but something aint right cant pin point it but i got a feeling something is wrong..
if your radio works without the key then the radio is wired direct to the bat.. if our power windows or any other electricl unit wotn work when the car is on the "on" posistion then i would suspect the ignition switch.. most of the electrical units run off the ignition switch.. but like everyone says.. check your bat if you have enough amps to turn the car or alos check your fuseable links too.. it might just be a simple fix... good luck man
Success :D:D she runs...i just hot wired it from the positive side of the battery too the coil... after 5mins of trying it went :)
But i still have Electrical Probs..Indicatiors dont work... :( also i cant turn the key to the on posistion without the dash lights coming on....
Radio worked when the Key was onto Acc.
  • Who's Online   2 Members, 0 Anonymous, 335 Guests (See full list)
