Posted November 23, 200321 yr comment_58051 my question is this, how hard is it to take the engine and fuel system out of a 76 280z and put it into a 240z...generaly speaking, I don't know if it will be worth the trouble or not, but I'd like the have the EFI with out the DEQ if you know what I mean.Parker Link to comment https://www.classiczcars.com/forums/topic/8999-280-to-240/ Share on other sites More sharing options...
November 23, 200321 yr comment_58052 From my understanding.....the motor will just bolt in.Using the same motor mounts and existing tranny.You might also have to put in the correct electric fuel pump. Link to comment https://www.classiczcars.com/forums/topic/8999-280-to-240/#findComment-58052 Share on other sites More sharing options...
November 23, 200321 yr comment_58058 Don't forget all the computer stuff and associated modifications to the wiring harness. It can be (and has been) done so it will not be a problem. Just make sure you have a donor vehicle so you are sure to get all the parts needed. Link to comment https://www.classiczcars.com/forums/topic/8999-280-to-240/#findComment-58058 Share on other sites More sharing options...
