Posted November 24, 200321 yr comment_58281 A post a while back said that he waited until the weather got cold and hit the floor pans lightly with a hammer to crack the floor tar. He said it was easy. Made me wonder.If you put dry ice in the floor and let it sit awhile???HMMMMM No fire, no chemicals......hmmmm Just a theory.Someone let me know! Link to comment https://www.classiczcars.com/forums/topic/9035-floor-tar-removal/ Share on other sites More sharing options...
November 24, 200321 yr comment_58282 I don't see why it wouldn't work. HOWEVER, instead of worrying about heat burns from a torch or heat gun, you'll need to be careful to not get freeze burns from the dry ice. It will kill skin just as quick as heat will. Link to comment https://www.classiczcars.com/forums/topic/9035-floor-tar-removal/#findComment-58282 Share on other sites More sharing options...
November 25, 200321 yr comment_58309 Thats it, Carl. Your new name is Yin&yYang. You see good in evil, You have an up for every down, you see the black in the white, etc, etc, just pullin your leg.Anyways, your advise should be well heeded ( taken seriously )Dry ice can be nasty if your not careful.Dave Link to comment https://www.classiczcars.com/forums/topic/9035-floor-tar-removal/#findComment-58309 Share on other sites More sharing options...
November 25, 200321 yr comment_58413 Originally posted by Daniel floor tar Is this the rubbery / plastic material spread over the inside floor and console pannels?If so I don't think there is any paint under them, something to consider and my ones didn't take much heat to lift them off. Are you worried about damiging the under seal or surrounding paint? Link to comment https://www.classiczcars.com/forums/topic/9035-floor-tar-removal/#findComment-58413 Share on other sites More sharing options...
November 25, 200321 yr Author comment_58425 I'm not doing any.I'm just thinking outloud.Seems alot of post asking about removal. Just thinking about a possible new trick. Link to comment https://www.classiczcars.com/forums/topic/9035-floor-tar-removal/#findComment-58425 Share on other sites More sharing options...
