Posted November 25, 200321 yr comment_58410 -240z gas tank, good shape. make offer. need shelf space-5 speed tranny out of a '77 280 with t/o bearing. 5th gear synchro is shot, will grind half the time going into 5th. $30 and it's yours.-soon to be another 240z gas tank, with vapor tank with all new fuel lines in proper length for it, out of my car. painted with zero-rust and rubber coated with undercoating. make offer, but won't be available for a month-280z radiator modified to also fit into 240z frame. Comes with bolts and plastic fan shroud to air cooling. Make offer.this is fremont, california, zip 94539. local pickup only please, most of this stuff is too impractical to ship.-alex Link to comment https://www.classiczcars.com/forums/topic/9058-need-to-make-room-in-the-garage/ Share on other sites More sharing options...
November 30, 200321 yr comment_58861 please let me know if you change your mind on shipping would need the rad and shroud thanks Link to comment https://www.classiczcars.com/forums/topic/9058-need-to-make-room-in-the-garage/#findComment-58861 Share on other sites More sharing options...
