Comp. Oil pump comparison...
Zvoiture
Turbo pump has 15% more volume. Competition pump runs 90psi+. Both can be fitted with an external pickup to avoid the internal feed gallery restrictions. The next step from there is a dry-sump....
Fit a turbo pump if you have a turbo (no kidding...) or an external cooler. I've got both & pressure is around 50psi, hot (80 deg C after the cooler), 3000rpm, measured at the stock location on a mechanical gauge.
