Posted November 26, 200321 yr comment_58467 Pretty popular with the ricers. I don't really know how old of theory this is...perhaps it has been around for ages. This 'multi-ground' thingy--where a half-dozen or more fat ground wires run from the battery off to all over the engine. They bolt to just about anything that doesn't move. Is there any merit in this?steve77 Link to comment https://www.classiczcars.com/forums/topic/9066-multi-ground/ Share on other sites More sharing options...
November 26, 200321 yr comment_58468 Using the body as a return is dubious at the best of times.If it wasn't then all car electricals would be single wire!I suspect many of the zed electrical problems that we read about are brought about by PO's disregarding the negative return and relying on the body as a negative return rather than using a dedicated wire return to negative. Link to comment https://www.classiczcars.com/forums/topic/9066-multi-ground/#findComment-58468 Share on other sites More sharing options...
January 5, 200421 yr comment_62860 The ground trunk that you are describing is from the boating industry. Since boats are made from composites and fiberglass there is no way for current to return to the source, thus you have an incomplete circuit. Lately the aftermarket and repower sectors of the boating industry have gone to using mutiple battery gangs, good for hi/po & multiple engines. But for the other goodies and nick nacks that have become every day items that are all solid state and run off direct current. To complete these circuits in the boat the ground trunk evolved. usually one main ground with smaller branches coming off of it. That will all lead back to the source. This should work wonders for the Z if you wanted to rewire it. Better B+ feed to the system will require better ground return path. :devious: . Link to comment https://www.classiczcars.com/forums/topic/9066-multi-ground/#findComment-62860 Share on other sites More sharing options...
