R200 Aluminum rear brace $90 includes shipping in the states This lower rear brace is made to fit 70-78Z with the R200 Limited Slip Differential that has the finned rear cover. The brace is made from 6061 billet aluminum. It is bolted to the vertical risers with 1/2 inch grade 8 nuts, bolts and washers. The brace is high quality and machined on a vertical mill. I have redesigned the brace so that it is now bolted on with 4 bolts. The brace pictured on my web page is not the new design. For those interested I will E-mail a picture of the new design. I also have pre-drilled risers with the saddles or I have premium quality 1/2 inch Cobalt drill bits for drilling the risers. This brace can also be used on R230 conversions.
Aluminum brace $90
Pre-drilled risers with saddles $30
Cobalt drill bit $15
Dave...
http://www.linfoot.net
