On my 73 I've noticed that recently the ammeter bounces around a lot. Usually happens when I have the lights and/or fan running (ie. more load), but there are also times when the needle is rock solid in the center with them on, and then when I turn them off it starts bouncing. I cannot find a consistent cause and effect for this.
I saw this thread:
http://www.classiczcars.com/forums/showthread.php?s=&threadid=1868&highlight=ammeter
and last weekend thought I would open up the voltage regulator and clean the contacts. But the PO had swapped it for a solid state unit. I opened it up and all looks well, and the connectors all look to be making a good connection.
Any suggestions besides replacing the VR?
https://www.classiczcars.com/forums/topic/9150-bouncing-ammeter/
